My intentions for my stroker build were to A.) get more power B.) build a reliable engine and C.) do it inexpensively. I know the fast, reliable, cheap paradox where you can only pick two, this is more like where can I find x part for the cheapest. As I went through the process of putting parts lists together and making a budget I decided to spend a little extra money for some more power.
First off, here is what I have come up with from the stroker calculator. This was incredibly useful as it shows what quench is, and what factors effect Compression Ratio. I was shooting for 9.5 CR until I came across some pistons dished to 28cc and I was able to deck some of the head and block (.015" and .0415, respectively) to lower the CR to 9.1 and the quench to a much better than stock .060"
Here is the budget/parts list that I have come up with. In light of all the aftermarket cam failures Im electing to regrind the stock 95 cam, which has better specs than my 97 anyway. New cam, new valvetrain. The shim kit is needed to offset the shaving of the head and block.
As Im sure you can see Ive begun collecting parts. I will include shipping prices to get a more accurate picture of what this type of build will realitically cost. Hopefully I can post pics whenever I get something, cause everyone likes to look at fun stuff. Heres what Ive gotten so far:
258 connecting rods. I got these from C45m on ebay, I believe he now sells them for 130 without shipping.
I hadnt yet found out about the benefit of buying everything together in the rebuild kit so I got these connecting rod bearings shortly after getting the 258 rods. Im not sure if I will end up using them or not anymore, but here they are.
I found a good deal on some 24# Ford injectors on ebay. 56.50 for seven and one messed up one; I only need six! They are Denso F55E-A2E and after checking, they are high impedance, so they should work.
I was going to have to machine the whichever pistons I got to lower the CR to 9.5, but I found these for sale from Artsound (the guy who sells bored TBs on ebay) on Jeep forum. It would normally cost arond 250 to get pistons and have them machined, and I got these for $190. As I mentioned earlier they are machined to 28cc, which should be safe assuming that Dr Dyno lists the same pistons as being able to be machined to 30cc. The pistons are Silv-o-lite 2229s.
ARP connecting rod bolts, pn 112-6001 for cheap insurance (which, btw, adds up). Not much, but again pics are fun.
Since then I have gotten head bolts which fall under the category of cheap insurance. I dont have a picture but they are Fel-pro ES71102. Some people say you can reuse them, I would rather not risk it. I also got a shim kit from Summit to offset the head and block being shaved .0565". They have not yet arrived, pn CRN-99179-1. Just imagine a bunch of washers.
That is all I have for now. If anyone has any advice, questions, comments, criticisms, snide remarks, shoot them my way and Ill do what I can to answer them.
