4.0 roller cam options?
- I think I'll order a "tab"
ARe there any performance roller cam options for the 4.0 or am I limited to flat tappet?
- Plechtan
- Vehicle Model: Comanche
Re: 4.0 roller cam options?
no production roller cams or lifters. you are only limited by the size of your wallet
Peter Lechtanski
- Stroker Displacement: 4.9
[quote="Plechtan"]no production roller cams or lifters. you are only limited by the size of your wallet[/quote]
BUT there will be soon........That is all I am going to say.
That is just down right mean.. making a statement like that then not telling us more!! With my luck it will come out a week after I get my engine in my XJ.jsawduste wrote: BUT there will be soon........That is all I am going to say.
That's how I felt about the KBs, Chris, except they came out a day or two before I built mine(luckily I had both sets of rods so I could go either way). At least there's not a person from a company claiming they'll be out at a certain time, or giving you the run around. The last I heard on the cam was $800 from the now done for Crane.
- Learning to use the board
I'd be interested in knowing anything more about this.
This was massively researched right up to getting the blanks made when the needed 5 buyers could not be found and the project halted.
I haven't been around here much, but Nick Alfano an AMC guy is working on getting AMC V8 roller cams made now that Crane has gone belly up.
I was wondering if there is any interest or progress being made on the six cylinder roller cam, or if we could perhaps talk Nick into looking into it at the same time as doing the V8 cam.
I am this close >< to building my lowbuck 4.5L and the thought is crossing my mind that my existing 4.0L would make a perfecto test mule for a 4.0L roller cam.
I probably won't be ready to do anything till mid summer as I have what I hope is one more round of medical stuff to go through first
Mark
1969 AMC Rambler, 4.0L,H.O efi, T5
1997 XJ Sport, 4.0L, AX15
2004 WJ 4.7L,V8, Airraid Jr, Dynomax ultraflo, addco rear sway.
1965 Ambassador Convertible, rustbucket, Resident Evil, can't get it done, can't kill it...
- Plechtan
I have a shop looking at the blanks right now. He is guessing $500-$600 each for blanks. It could be cheaper if your cam grinder could work with round lobes and not need to have the lobes roughed in. It would also be less if you did not need the gear. ( external oil pump).
He wanted to make at least 5, i will buy 2, so if three other people are interisted we could move foward.
Peter Lechtanski
Brien Tourville forwarded this copied from NAXJA
Flash and Delk were the major players in getting blanks sent to Joe at Roto-faze.
I will likely be leaving people out etc,
Basically I will try and go through the Strokersgroup emails and see if I can sort out who did what and if we need to start over.
Joes blanks look to have better pricing.
Crane is gone
Unless Nick Alfano can get lifters back online for the AMC retrofit that option has dissapeared.
I see there is a pole in place on these cams too.
Anyway below is Briens forward to amc-list today
Here's aa copy of a copy of some info./BT
Here are the spec for owning a Hyd Roller Cam..............I copy and
pasted from the conversation on naxja back 07/19/2007 on the Roller cam.
ALL THE NUMBERS ARE IN...........
This is what it will take to own a roller cam.
there must be 6 orders Before Joe will start.
Joe said that there must be at least 50% down on all 6 cam blanks
The price from Joe is: $485.25 for the cam blank.(%50 would be 242.63)
The first Cam grind shop that Joe recommended is in California
"SCHNEIDER CAMS" There # IS 619-297-0227, Talk to Jerry.
Price.... ......... $450
East coast(Florida) Then Crane was the
recommended cam grind shop.
Crane Cam's: talk to Chase KNight at 386-252-1151 ext.#402
Cam Grind $468.00, (any profile) Chrome molly push rods "$80.00",
V8
Hyd Roller lifters ( set of 12)...Chase said that he would give us
the good guy discount $337.00..... .. is actual words were
the "installer discount"!
OK now to make the price PERFICTLY CLEAR!!!
ROTO- FAZE CAM BLANK W/ DISTRIBUTOR GEAR CUT .........................485.25
CAM BLANK GROUND IN TO WHAT EVER CAM PROFILE YOU DESIRE!!!........450.00
TO....468.00
CHROME MOLY PUSHROD (IF NEEDED, DO TO HEAD DECKING OR DIFFERENS IN HIGHT
BETWEEN ROLLER LIFTER AND STOCK FLAT TAPPET
LIFTER..................................80.00
AMC V8 ROLLER LIFTERS (SET OF 12)
............................................337.00
TOTAL........................................................................$1,272.25
TO 1,370.25
I for got Joe's number..........If some one was wanting to buy a single
cam. Joe said that he would.......BUT it would cost more......But, as i
have said before, thats his specialty, is building one of a kind cams
and what not!!!!!!
Joe @ Roto-Faze Ignitions and Equipment
23136 Mariposa Avenue, Torrance, California 90502
(310) 325-8844 or Fax (301) 539-1828
For any one interest in this endeavor........Joe quoted me a 4 to 6 week
turn around for his work and then how ever long it would take at the cam
grinders................
I'm sure delk, will add his info soon...............
Like i said before, the road has been marked........It just needs some
one to pave it!!!!!
"Flash"
Crane is gone
V8
TO....468.00
TO 1,370.25
and what not!!!!!!
one to pave it!!!!!
Mark
I don't want to clutter up that forward so I'll add my thoughts here.
Who here remembers the project from the strokers group and has more info?
Is any of that info still good do we think?
To me, there is one or two things that have me waffling on going for it.
Biggest one is lifters.
With Crane gone, is there going to be an option? even if we can get them online again will they fit in all the positions of the six?
What good is a blank if the lifters don't fit?
I for one don't want a solid lifter and don't want a block machining chore involved with this.
I want a bolt in setup. as in a true retrofit.
Idealy this will be very marketable if done correctly. There are a ton of AMC sixes out there.
I don't want to reinvent the wheel on this if the work is being done and something is on the horizon.
Last time I had issues that stopped me from getting involved. I still have a procedure coming up that will sideline me for half the summer if it works.
But that will probably leave me able to do things again! Instead of being in pain all the time. I have a trial of the treatment that starts on the 11th. I should know if it will work by 18th and be sure of what is going on fully by the end of the month.
If we can work out a full plan to get the blanks back on track I should be able to actually buy one.
My plan would be to buy the blank, have it machined and work out the specifics of the install. Then put it into the 4.0L in my American for a breakin thrash, test and tune etc, If all goes well and nothing breaks I would tranfer it to a 4.5L later. If it breaks the motor, I have a 4.5L waiting in the wings for the American.
Mark
- Plechtan
The 500-600 price was a guess, if the going price is $485.00 then that will be the price. This is for a 8620 billet cam blank, correct? My guy can turn them around in 2-3 weeks.
I am working with Isky on a solid roller solution, the hydrauic roller you are probably stuck with using the AMC V8 stuff. It roller cam is not cheap, even for a production one.
Peter Lechtanski
- Plechtan
Crowler makes a hydraulic roller lifter with a tiebar, maybe they will make a custom, or a standard size will fit.
Peter Lechtanski
I wasn't trying to talk down pricing or anything at this point. I just got reinterested when Nick Alfano started talking about keeping the roller cam available for the AMC V8 and someone else over at the amc-list pointed out the loss of the retrofit lifter we had talked about using in the six.Plechtan wrote:The 500-600 price was a guess, if the going price is $485.00 then that will be the price. This is for a 8620 billet cam blank, correct? My guy can turn them around in 2-3 weeks.
Is the blank you are looking at going to be distributor friendly and such? I can't recall all the details that required. It's been while since we went through all this on the group.
Like I said I have a few weeks to lock down details on how my life will go. Then I can fully committ to at least being in for a blank!
Mark
- Plechtan
I do not need a distributor gear or fuel pump cam for my application, but I thought it would be a good idea to have the gear on it. I was also playing around with the front of the cam. The first ones will probably have the standard cam design that was used prior to 1999, I may make some that will take a Ford 351C cam gear. Turns out that the cam to crank spacing is the same, and you can get a Cloyes Hex adjust setup for the 351C. the crank gear and chain would be the same as the Jeep double roller from Cloyes.
Peter Lechtanski
- Plechtan
Solid Lifters:
Talked to Isky today, they recommended part # 3372RH for the lifter. they sell the tie bars separately. They said the ford 429 tiebar would work, but .070 of material would have to be removed from the root of the forks, or .035 per side. The dimension of the bar is 1.750 and the AMC would require 1.680. I don't know if you could use the Isky bars with Comp Cam hydraulic roller lifters.
The lifter is 1.605" tall. (info for pushrod length)
Peter Lechtanski
I hit the numbers on those lifters and I understand you have to pay to play, but those are pretty darned expensive!
I've had zero luck in getting an idea on what those lifters even fit! Iskys website leaves a lot to be desired
Mark
