Maybe this should be move to FAQ section
Cylinder spacing on a 4.0 Block is 4.380" center to center. Lifter bore spacing is 2.02 center to center .903 lifter, Center pushrod, oil through pushrod.
Cylinder spacing on 4.0 block
- Plechtan
- Vehicle Model: Comanche
Peter Lechtanski
yuppiexj
Re: Cylinder spacing on 4.0 block
Isn't that the same bore spacing as a SB Ford?
runs to drop a pair of Dart Windsor heads on the band saw to create the awesomest 4.0 crossflow head.
- Muad'Dib
I added your post to the FAQ's Thanks!
- Alex22
Head bolts don't line up.
- Plechtan
Maybe you could buy the heads directly from Dart and ask them not to drill the head bolt holes. A welder does wonders with an aluminum head.
I wonder if they kept the same spacing with the OHC motors?
Peter Lechtanski
lafrad
ooo... OHC would be interesting... probably start running into limits on the strength of the block and parts there....
- Plechtan
The Ford modular engines use a 100mm cylinder spacing, that is less than 4 inches. I wonder what the spacing is on the Chevy (4.3?) inline 6 they use in the trailblazers, that is an OHC motor.
Peter Lechtanski
Users browsing this forum: Amazon [Bot], Google [Bot] and 3 guests
