Can a guy take a 64mm 4 weight crank and have 10mm shaved off the front so I don't have to buy a spacer?
Thanks
dean
Crankshaft Machining
dingo151
Re: Crankshaft Machining
Yes
dingo151
Thanks Man!
When this is done, does the bolt hole need to be re-tapped? Or is it still deep enough for the HB bolt after being shaved?
