One is an of fft fft fft fft sound that is rhythmic and increases with engine RPM. I can't pin point it and it doesn't sound like it is coming from the valve train. Not very loud, but its easier to hear when you step back form the vehicle, but faint up close. Although the best I can hear it it sounds like it is coming from the passenger side near the dipstick area.
The other condition is a momentary lean condition. The lean condition is a bit of a stumper. It happens in closed and open loop, when cold (should be open loop) and while just driving around up to full temp (closed loop), I haven't put the pedal down enough to force it into open loop acceleration. It also appears to happen while driving, accelerating and idling both in gear and park/neutral. Watching the AFR gauge it will go from 14.7 down to like 16-19:1 AFR. It will stay there for a bit then come back to the correct 14.7:1. When this happens it hesitates until the AFR returns to 14.7:1 or so. It hasn't stalled out from this and the PCM is not throwing any codes. No back fire or anything weird either. I tipple checked all the connections on the sensors. and they are all plugged in. So, tomorrow I will plug in my OBD II scan software (if it works) and try to see what is happening. Any ideas? I am also going to try to locate a fuel pressure gauge and test that.
-Chris
