Cam Question
Plechtan
Cam Question
Post by Plechtan »
I was looking at the Comp Cams catlaog at their 68-200-4 cam, it is 252 adverised duration and 206 @ ,050. I checked my Mopar Jeep engines book, and it quotes the adverised duration of the stock @ 270 deg. it does not show ,050 numbers. Lift o the Comp cams was .433 and the stock was .405 So the Comp cams does open a little wider, but seems to have a shorter duration.
Has anybody else looked at aftermarket cams vs the stock 4.0 cam?
Peter Lechtanski
RAPTORFAN85
Re: Cam Question
Post by RAPTORFAN85 »
Stock duration at .050 is only 197. It ramps up slowly, peaks quickly and then slowly ramps down again. Not very performance oriented. I have looked at stock vs. after market cams. I ran the stock cam for a little while and I wasn't impressed. I am in the process of swapping in the comp 68-201-4 with a set of 1.7 roller rockers. My end specs will be .475 lift, 260 dur. advertised and 212 @ .050, LSA of 110 and 4* advance. I will let you know the results when I finally get it back together.
"Strrrrroke me, stoke me...."
Billy Squire
