Hey,
How important is it that you groove the lifter bores or run camsaver lifters? Do 4.0's have a problem with cam life or is this just a precaution.
Thanks
Dean
Lifter Bore Grooving
dingo151
Re: Lifter Bore Grooving
All flat tappet cams may be subject to failure, since the reduction of Zinc in the oils. You need to run oil with higher Zinc levels. I have read flat tappet cams need at least 1200ppm zinc.
