Thrust pin and spring
Maddawg
Vehicle Model: G.Cherokee
Post by Maddawg »
Could anyone tell me if the crankshaft cover is what the thrust pin and spring ride on? I guess I'm have trouble understanding the purpose of this. Thanks Dale
2000 Grand Cherokee 4.6
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Re: Thrust pin and spring
Post by dwg86 »
Yes, it rides on the timing chain cover. Its supposed to keep the cam from walking forward.
Maddawg
Post by Maddawg »
Thanks, just was consernd since I was unable to use the thrust plate with the new cam ,timing chain, etc!
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Post by John »
Consider getting a new spring /pin for this conversion, some find a older weak spring can cause serious problems.
Maddawg
Post by Maddawg »
My new cam came with spring and pin. Thanks
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
ccpanel
Stroker Displacement: 275
Vehicle Year: 1950
Vehicle Make: chevy
Vehicle Model: truck
Post by ccpanel »
Maddawg wrote:My new cam came with spring and pin. Thanks
what about the "rub plate" inside stock timing cover-do i need that with the brand new cloyes double roller chain?
RAPTORFAN85
Vehicle Year: 2001
Vehicle Model: TJ
Post by RAPTORFAN85 »
DWG and I are both running this mod with no problems. I am sure you could do something similar and it would work also. Oh and thanks DWG it works great!
http://www.jeepstrokers.com/forum/viewt ... +COVER+MOD
"Strrrrroke me, stoke me...."
Billy Squire
Maddawg
Post by Maddawg »
I was thinking of something similar using a small hardened bolt and nylon bolt. Where can I locate the aircraft screw?
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Post by dwg86 »
Maddawg wrote:I was thinking of something similar using a small hardened bolt and nylon bolt. Where can I locate the aircraft screw?
Sent you a PM.
Maddawg
Post by Maddawg »
Thanks I replied :cheers:
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
