Thrust pin and spring
- Maddawg
- Vehicle Model: G.Cherokee
Could anyone tell me if the crankshaft cover is what the thrust pin and spring ride on? I guess I'm have trouble understanding the purpose of this. Thanks Dale
2000 Grand Cherokee 4.6
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Re: Thrust pin and spring
Yes, it rides on the timing chain cover. Its supposed to keep the cam from walking forward.
- Maddawg
Thanks, just was consernd since I was unable to use the thrust plate with the new cam ,timing chain, etc!
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
- John
Consider getting a new spring /pin for this conversion, some find a older weak spring can cause serious problems.
- Maddawg
My new cam came with spring and pin. Thanks
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
- ccpanel
- Stroker Displacement: 275
- Vehicle Year: 1950
- Vehicle Make: chevy
- Vehicle Model: truck
Maddawg wrote:My new cam came with spring and pin. Thanks
what about the "rub plate" inside stock timing cover-do i need that with the brand new cloyes double roller chain?
- RAPTORFAN85
DWG and I are both running this mod with no problems. I am sure you could do something similar and it would work also. Oh and thanks DWG it works great!
http://www.jeepstrokers.com/forum/viewt ... +COVER+MOD
"Strrrrroke me, stoke me...."
Billy Squire
Billy Squire
- Maddawg
I was thinking of something similar using a small hardened bolt and nylon bolt. Where can I locate the aircraft screw?
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Sent you a PM.Maddawg wrote:I was thinking of something similar using a small hardened bolt and nylon bolt. Where can I locate the aircraft screw?
- Maddawg
Thanks I replied
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
SRC 10.03 DRC 7.74
Deck height .010
Head shaved .010
Bore .030
Rugged Ridge Header
Users browsing this forum: Google [Bot], LJBean and 2 guests
