hi-er flow factory intake
Zjdamien
Vehicle Year: 1993
Vehicle Model: ZJ
Post by Zjdamien »
watched a exterme 4x4 the other day they built a 4.6 stroker and used a sertin year intake that flowed better then old intakes cant remember what year they used. anyone know what year intake flow better?
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Re: hi-er flow factory intake
Post by amcinstaller »
youre looking for the 1999+ "squid or octopus" style. oval plenum, equal length curved runners. grab the matching ps pump unless you like fabbing brackets to use your old one
amcinstaller wrote: grab the matching ps pump unless you like fabbing brackets to use your old one
The '97 up pumps bolt right up, all I had to change was one vacuum fitting, cap several others, lengthen one vacuum hose, and lengthen the AIT sensor wire, everything else bolted right back up.
