hi-er flow factory intake
Zjdamien
- Vehicle Year: 1993
- Vehicle Model: ZJ
watched a exterme 4x4 the other day they built a 4.6 stroker and used a sertin year intake that flowed better then old intakes cant remember what year they used. anyone know what year intake flow better?
- Vehicle Year: 1980
- Vehicle Make: AMC
- Vehicle Model: Spirit
Re: hi-er flow factory intake
youre looking for the 1999+ "squid or octopus" style. oval plenum, equal length curved runners. grab the matching ps pump unless you like fabbing brackets to use your old one
The '97 up pumps bolt right up, all I had to change was one vacuum fitting, cap several others, lengthen one vacuum hose, and lengthen the AIT sensor wire, everything else bolted right back up.amcinstaller wrote: grab the matching ps pump unless you like fabbing brackets to use your old one
