Hesco says not to run the timing chain tensioner/guide with a double roller. Can't figure out why though. I'm rebating removing the one on mine and removing the slots that hold it to the cover.
Keep or remove?
No timing chain tensioner/guide with a double roller?
bbarrett
- Stroker Displacement: 331
- Vehicle Year: 1987
- Vehicle Model: wrangler
Re: No timing chain tensioner/guide with a double roller?
I kept mine, Running the Cloves double roller chain. I did put in a new rubbing block.
TEST
go4lo
- Vehicle Model: MJ
I put a new tensioner/guide in with the JP Double Roller set in mine.
I'm running a JP double roller with the stock guide. Over 12,000 miles on my stroker.
- unlimitedrubicon
- Vehicle Year: 2005
Have you asked them to see what their reason was for the recommendation? That seems like the best place to start.
They said a) is not needed and b) not enough room. I removed it. I saw no purpose considering it is on the tension side of the chain. I.e. it wouldn't take up slack, just screw with the cam timing. Stupid design IMO.
Users browsing this forum: mpgMike and 7 guests
