No timing chain tensioner/guide with a double roller?
Hesco says not to run the timing chain tensioner/guide with a double roller. Can't figure out why though. I'm rebating removing the one on mine and removing the slots that hold it to the cover.
Keep or remove?
bbarrett
Stroker Displacement: 331
Vehicle Year: 1987
Re: No timing chain tensioner/guide with a double roller?
Post by bbarrett »
I kept mine, Running the Cloves double roller chain. I did put in a new rubbing block.
TEST
go4lo
Vehicle Model: MJ
Post by go4lo »
I put a new tensioner/guide in with the JP Double Roller set in mine.
I'm running a JP double roller with the stock guide. Over 12,000 miles on my stroker.
unlimitedrubicon
Vehicle Year: 2005
Post by unlimitedrubicon »
Have you asked them to see what their reason was for the recommendation? That seems like the best place to start.
They said a) is not needed and b) not enough room. I removed it. I saw no purpose considering it is on the tension side of the chain. I.e. it wouldn't take up slack, just screw with the cam timing. Stupid design IMO.
