what am i missing?
bradcarrier
Where's the "any" key?
Vehicle Year: 1995
what am i missing?
Post by bradcarrier »
About to install my stroker in my 95 jeep yj. I've got the 24# blue top injectors, just ordered my luk pro gold clutch clutch, do I need anything else to make this work with with my jeep. Do I need a different pilot bearing because of the 4.2 crank, anything else I'm missing? Thanks
Missourian
Re: what am i missing?
Post by Missourian »
Pilot bearing is the same and make sure you replace your throw out bearing while you are doing all this to reduce risk of having to pull it all back apart.
I have a 4.6L STOKER in my 2000 Jeep Wrangler with 4.5" lift on 35" BFG MT and 4.56:1 gears.
Check out Metro Crawlers Image
You'll need pilot bearing no. 53009180AB.
bradcarrier
Vehicle Year: 1995
Cheromaniac wrote:You'll need pilot bearing no. 53009180AB.
You must be DINO, thanks for all the good info!!!
6TIME
Consistent
Consistent
Vehicle Year: 1993
Vehicle Make: JEEP
Vehicle Model: CHEROKEE
Post by 6TIME »
That Mopar pilot bearing number crosses over to a TIMKEN/BCA/NATIONAL part #FC69907, That might be more readily available in local parts stores if they have problems cross referencing from the Mopar #....
Yup. I'm Dino and you're welcome. :D
