what am i missing?
bradcarrier
- Vehicle Year: 1995
- Vehicle Model: wrangler
what am i missing?
About to install my stroker in my 95 jeep yj. I've got the 24# blue top injectors, just ordered my luk pro gold clutch clutch, do I need anything else to make this work with with my jeep. Do I need a different pilot bearing because of the 4.2 crank, anything else I'm missing? Thanks
Missourian
Re: what am i missing?
Pilot bearing is the same and make sure you replace your throw out bearing while you are doing all this to reduce risk of having to pull it all back apart.
- Vehicle Make: Jeep XJ
You'll need pilot bearing no. 53009180AB.
bradcarrier
You must be DINO, thanks for all the good info!!!Cheromaniac wrote:You'll need pilot bearing no. 53009180AB.
6TIME
- Vehicle Year: 1993
- Vehicle Make: JEEP
- Vehicle Model: CHEROKEE
That Mopar pilot bearing number crosses over to a TIMKEN/BCA/NATIONAL part #FC69907, That might be more readily available in local parts stores if they have problems cross referencing from the Mopar #....
Yup. I'm Dino and you're welcome.bradcarrier wrote:You must be DINO, thanks for all the good info!!!Cheromaniac wrote:You'll need pilot bearing no. 53009180AB.
