Question about injector timing w after market mild crawler cam.
Hi all
4.0 Chrysler engine,. stock computer, Low buck stroker.
500 miles on rebuild
Jeep drives great but has lost some power.
Distributor: I cut the tabs off to get it started.
I have read to locate the center of two points (Rotate to both extreams to find the bad places than bolt the distributor down at the center point between them.
It seems that injector timing would be more critical than that.
I seems to me it could cause problems if not correct.
Injectors firing to soon or to late??
I am somewhat new here and have been reading till my eyes bleed ,
Any suggestions would be greatly appreciated.
Injector timing w after market cam
tequila mike
- Learning to use the board
- Stroker Displacement: 4.6?
- Vehicle Year: 1991
- Vehicle Make: heep
- Vehicle Model: wrangler
604rail_king
- Vehicle Year: 1995
Re: Injector timing w after market cam
What can are you specifically running? And what injectors?
tequila mike
Thanks so much for the quick response
CompCams 68-231-4 206/214 degree cam.
ford 24#
If i cant find more accurate info i will use t cheromaniac's link.
The part i have a problem with is close and near in the information in the article
Thanks again for the responses.
Michael
ford 24#
Michael
