Injector timing w after market cam
tequila mike
Learning to use the board
Stroker Displacement: 4.6?
Vehicle Year: 1991
Vehicle Make: heep
Post by tequila mike »
Question about injector timing w after market mild crawler cam.
Hi all
4.0 Chrysler engine,. stock computer, Low buck stroker.
500 miles on rebuild
Jeep drives great but has lost some power.
Distributor: I cut the tabs off to get it started.
I have read to locate the center of two points (Rotate to both extreams to find the bad places than bolt the distributor down at the center point between them.
It seems that injector timing would be more critical than that.
I seems to me it could cause problems if not correct.
Injectors firing to soon or to late??
I am somewhat new here and have been reading till my eyes bleed ,
Any suggestions would be greatly appreciated.
604rail_king
Vehicle Year: 1995
Re: Injector timing w after market cam
Post by 604rail_king »
What can are you specifically running? And what injectors?
tequila mike
Vehicle Year: 1991
Vehicle Make: heep
Thanks so much for the quick response
CompCams 68-231-4 206/214 degree cam.
ford 24#
If i cant find more accurate info i will use t cheromaniac's link.
The part i have a problem with is close and near in the information in the article
Thanks again for the responses.
Michael
Users browsing this forum: Bing [Bot], Semrush [Bot] and 5 guests
