Oil Pump?
- Vehicle Year: 1995
Re: Oil Pump?
it really comes down to personal preference (or budget) as both work fine.
from what i gathered when researching, many went with the High Volume Melling for a few key reasons. i went with the HV also (yet to be installed). it does require you to massage the pan though.
- EVIL95XJ
- Muad'Dib
Re: Oil Pump?
No need for the HV unless you plan on running loose bearing clearances.
- IH 392
Re: Oil Pump?
YEP!, if your clearances are correct there is NO need for an oil heater pump!Muad'Dib wrote:No need for the HV unless you plan on running loose bearing clearances.
- cruiser54
- Vehicle Model: Comanche
Re: Oil Pump?
Know where the HV oil pump came from? It wasn't developed for any particular high performance applications. According to my buddy at JeepTech, it was a military specified pump for some 4.0s that the military used in certain applications and that had a different oil pan. I use them.
www.cruiser54.com
www.cruiser54.com
Re: Oil Pump?
Different oil pan? Does he know what was different about them?
The Mopar stroker comes with a HV pump for some reason.
- cruiser54
Re: Oil Pump?
SilverXJ wrote:Different oil pan? Does he know what was different about them?
Actually straighter cut gears than stock and obviously a bit longer gears. The stock pump has barely discernable angle to the gears.
www.cruiser54.com
www.cruiser54.com
Re: Oil Pump?
I was asking about the oil pan.cruiser54 wrote:Actually straighter cut gears than stock and obviously a bit longer gears. The stock pump has barely discernable angle to the gears.
- cruiser54
Re: Oil Pump?
Who knows what the engines were in. Maybe they didn't need to clear a front axle.
www.cruiser54.com
www.cruiser54.com
Re: Oil Pump?
I would assume it was a Jeep, most likely a XJ or TJ.
- cruiser54
Re: Oil Pump?
I'll ask him when I get a chance. For some reason I seem to think it was some kind of equipment power plant.
www.cruiser54.com
www.cruiser54.com
Re: Oil Pump?
What he said. A HV oil pump isn't really necessary unless you have loose bearing clearances but if you do use one anyway, just make sure your cold start oil pressure isn't above 60psi otherwise you could accelerate distributor gear wear. If necessary use a thinner grade of oil.604rail_king wrote:it really comes down to personal preference (or budget) as both work fine.
- cruiser54
Re: Oil Pump?
My oil pressure is not particularly high at all. Same as my Comanche with stock oil pump.
www.cruiser54.com
www.cruiser54.com
