Oil Pump?
EVIL95XJ
Vehicle Year: 1995
Vehicle Model: cherokee
Oil Pump?
Post by EVIL95XJ »
high volume or not?
Ford 24# injectors - PM me
604rail_king
Vehicle Year: 1995
Re: Oil Pump?
Post by 604rail_king »
it really comes down to personal preference (or budget) as both work fine.
from what i gathered when researching, many went with the High Volume Melling for a few key reasons. i went with the HV also (yet to be installed). it does require you to massage the pan though.
EVIL95XJ
Vehicle Year: 1995
Re: Oil Pump?
Post by EVIL95XJ »
no real pros or cons besides the pan?
Re: Oil Pump?
No need for the HV unless you plan on running loose bearing clearances.
Re: Oil Pump?
Muad'Dib wrote:No need for the HV unless you plan on running loose bearing clearances.
YEP!, if your clearances are correct there is NO need for an oil heater pump!
cruiser54
Re: Oil Pump?
Post by cruiser54 »
Know where the HV oil pump came from? It wasn't developed for any particular high performance applications. According to my buddy at JeepTech, it was a military specified pump for some 4.0s that the military used in certain applications and that had a different oil pan. I use them.
www.cruiser54.com
Re: Oil Pump?
Different oil pan? Does he know what was different about them?
The Mopar stroker comes with a HV pump for some reason.
cruiser54
Re: Oil Pump?
Post by cruiser54 »
SilverXJ wrote:Different oil pan? Does he know what was different about them?
Actually straighter cut gears than stock and obviously a bit longer gears. The stock pump has barely discernable angle to the gears.
www.cruiser54.com
Re: Oil Pump?
cruiser54 wrote:Actually straighter cut gears than stock and obviously a bit longer gears. The stock pump has barely discernable angle to the gears.
I was asking about the oil pan.
cruiser54
Re: Oil Pump?
Post by cruiser54 »
Who knows what the engines were in. Maybe they didn't need to clear a front axle.
www.cruiser54.com
Re: Oil Pump?
I would assume it was a Jeep, most likely a XJ or TJ.
cruiser54
Re: Oil Pump?
Post by cruiser54 »
I'll ask him when I get a chance. For some reason I seem to think it was some kind of equipment power plant.
www.cruiser54.com
Re: Oil Pump?
604rail_king wrote:it really comes down to personal preference (or budget) as both work fine.
What he said. A HV oil pump isn't really necessary unless you have loose bearing clearances but if you do use one anyway, just make sure your cold start oil pressure isn't above 60psi otherwise you could accelerate distributor gear wear. If necessary use a thinner grade of oil.
cruiser54
Re: Oil Pump?
Post by cruiser54 »
My oil pressure is not particularly high at all. Same as my Comanche with stock oil pump.
www.cruiser54.com
