Think I screwed up...Can someone check my math?
dingo151
Post by dingo151 »
Hi,
Couldn't figure out why it seemed like my 4.6 was running lean out of desperation I started going back and rechecking everything that I'd bolted on and ran my injector numbers.
I had a 0280-156-013 injector which I thought when I bought it was a 24lb injector but when I run through my calculator it keeps coming up as a 21lb. :doh: Guess that would be a little small for a 4.6 with a 231 cam, Borla header and 99 intake.
Was wondering if I'm doing something wrong?
Thanks!
Dean
"You'll bunk with private Joker. He's silly and he's ignorant but he's got GUTS and guts are enough!"
Re: Think I screwed up...Can someone check my math?
What year?
dingo151
Post by dingo151 »
Its a 91. OBD1 no tweaking
Way too small. They flow 16.35lb @43.5 psi.Even less on the 39 psi rail. How long have you been running it like this?
Although a few sites list them at 22lb/hr, however sites like Stann Weiss, and other reputable list them at 16.35.
SilverXJ wrote:Way too small. They flow 16.35lb @43.5 psi. Even less on the 39 psi rail.
x2. Definitely way too small.
dingo151
Post by dingo151 »
Not very long....maybe 200 miles. Couldn't ever figure out why I was so lean....guess now I know. If I go to a set of Ford injectors A302's would they be big enough?
What is an A302?
dingo151
Post by dingo151 »
Ford Motorsport 24.0lb/hr @ 39psi (Part no. FMS-M9593-A302)
dingo151 wrote:Ford Motorsport 24.0lb/hr @ 39psi (Part no. FMS-M9593-A302)
I'm using those.
dingo151
Post by dingo151 »
THANKS!
Users browsing this forum: Bing [Bot], Semrush [Bot] and 1 guest
