renix stroker troubles
mousechez
- Vehicle Year: 1989
i built a stroker on renix - with adjustable fpr and map - 24lb injectors - idle is good - wot is great - wont level off above 1800 rpm - need help
Re: renix stroker troubles
What do you mean by "won't level off"?
mousechez
it bucks and backfires
Have you checked your TPS alignment?
- cruiser54
- Vehicle Model: Comanche
When you put the engine in, did you get all the small ground wires reinstalled at a clean and shiny spot at the engine dipstick tube stud?
www.cruiser54.com
www.cruiser54.com
mousechez
new tps - and adjustment - grounds all good
mousechez
tps .8 volts at closed and graduates to 4.8 at wot - map adjusted to around 6.5 volts input
- cruiser54
MAP voltage input is rather high considering stock is about 4.8. Try 5.1 or so.
What fuel pressure are you running with and without the vac line on the fuel pressure regulator?
www.cruiser54.com
www.cruiser54.com
mousechez
i dont have a pressure gage - just reset map to 5.4 whithout change - ill pick up a gage tomorrow
Could be a bad fuel pump, clogged fuel filter, or kinked fuel line.mousechez wrote:it bucks and backfires
mousechez
ok got 43lbs at fuel rail with vacuum and 49 without
- cruiser54
That's quite high. Should be 31 with and 39 without.
www.cruiser54.com
www.cruiser54.com
Yes, that pressure is too high.
- cruiser54
Between the high fuel pressure and high MAP supply voltage, it's gotts be real rich.
www.cruiser54.com
www.cruiser54.com
mousechez
well i set map and fpr back to stock and condition worsened
Users browsing this forum: Bing [Bot] and 6 guests
