renix stroker troubles
mousechez
Vehicle Year: 1989
Post by mousechez »
i built a stroker on renix - with adjustable fpr and map - 24lb injectors - idle is good - wot is great - wont level off above 1800 rpm - need help :brickwall:
Re: renix stroker troubles
What do you mean by "won't level off"?
mousechez
Vehicle Year: 1989
Post by mousechez »
it bucks and backfires
Have you checked your TPS alignment?
cruiser54
Post by cruiser54 »
When you put the engine in, did you get all the small ground wires reinstalled at a clean and shiny spot at the engine dipstick tube stud?
www.cruiser54.com
mousechez
Vehicle Year: 1989
Post by mousechez »
new tps - and adjustment - grounds all good
mousechez
Vehicle Year: 1989
Post by mousechez »
tps .8 volts at closed and graduates to 4.8 at wot - map adjusted to around 6.5 volts input
cruiser54
Post by cruiser54 »
MAP voltage input is rather high considering stock is about 4.8. Try 5.1 or so.
What fuel pressure are you running with and without the vac line on the fuel pressure regulator?
www.cruiser54.com
mousechez
Vehicle Year: 1989
Post by mousechez »
i dont have a pressure gage - just reset map to 5.4 whithout change - ill pick up a gage tomorrow
mousechez wrote:it bucks and backfires
Could be a bad fuel pump, clogged fuel filter, or kinked fuel line.
mousechez
Vehicle Year: 1989
Post by mousechez »
ok got 43lbs at fuel rail with vacuum and 49 without
cruiser54
Post by cruiser54 »
That's quite high. Should be 31 with and 39 without.
www.cruiser54.com
Yes, that pressure is too high.
cruiser54
Post by cruiser54 »
Between the high fuel pressure and high MAP supply voltage, it's gotts be real rich.
www.cruiser54.com
mousechez
Vehicle Year: 1989
Post by mousechez »
well i set map and fpr back to stock and condition worsened
