Stock timing is used?
jeep7081
Learning to use the board
Post by jeep7081 »
Stock timing is used when putting a comp cam in "231"?
MoFo
Vehicle Year: 1987
Re: Stock timing is used?
Post by MoFo »
What timing are you asking about, valve timing or ignition timing?
jeep7081
Post by jeep7081 »
Ignition
MoFo
Vehicle Year: 1987
Post by MoFo »
That depends on your engine controls. If you have the 4.0 donor, the computer is in control of ignition timing and you can't change that.
jeep7081
Post by jeep7081 »
Just did a cam and performance head swap. Thanks for info.
FlyinRyan
Post by FlyinRyan »
Controlled by the PCM.
Flyin' Ryan Performance
jeep7081
Post by jeep7081 »
dizzy needed to be indexed. Problem solve. She is running. :)
