Stock timing is used when putting a comp cam in "231"?
Thanks
Stock timing is used?
- jeep7081
- Learning to use the board
- Vehicle Model: XJ
MoFo
- Vehicle Year: 1987
Re: Stock timing is used?
What timing are you asking about, valve timing or ignition timing?
- jeep7081
- Vehicle Model: XJ
Ignition
MoFo
That depends on your engine controls. If you have the 4.0 donor, the computer is in control of ignition timing and you can't change that.
- jeep7081
- Vehicle Model: XJ
Just did a cam and performance head swap. Thanks for info.
FlyinRyan
Controlled by the PCM.
- jeep7081
- Vehicle Model: XJ
dizzy needed to be indexed. Problem solve. She is running.
Users browsing this forum: Amazon [Bot] and 2 guests
