Jeep 2.5 may go fast!
AMX's, Gremlins, Pacers, Ramblers, Eagles etc.
TurboTom
Post by TurboTom »
Starting a little project :doh:
Going in my Drag Spirit. Boosted of course
Alright...lets get crazy.
Left head 50 lbs, right head 20 lbs
One row of bolts line up (but have to be shifted to center combustion chambers) and yes the pushrods all go up and down!
Since the head has symmetrical ports, a custom camshaft will be needed. I will probably run a dry sump system so I will not need the dist. gear cut on the cam. Ignition will be coil on plug with a 60-2 wheel for injection and timing control.
Just a little eye candy
1979 AMC Spirit
Building a Turbo 2.5
I am not very smart!
Vehicle Make: Jeep XJ
Re: Jeep 2.5 may go fast!
Cool stuff. That's definitely a Jeep 2.5 block but from which engine did the head come from?
TurboTom
Post by TurboTom »
LS-1 Chevy
1979 AMC Spirit
CobraMarty
Post by CobraMarty »
Bore centers are the same on the LS-1 head?
99 XJ M62 S/C
TurboTom
Post by TurboTom »
Close enough... :mrgreen:
The cam will be the hard part
1979 AMC Spirit
mountaineerjeff
Stroker Displacement: 4.0
Vehicle Year: 1999
Post by mountaineerjeff »
whoa, hold the phone.....why cant I make a I6 out of 2 of these like they did back in the day, and then have a high flowing, cross flow, lightweight I6 option?
build thread http://www.cherokeeforum.com/f46/offici ... ep-179516/
N/A 14.9@89
N2O 12.7@104
I know LS heads have been welded together to create a LS V12 engine. http://ls1tech.com/forums/conversions-h ... build.html
How well do the coolant ports line up and where would the t-stat and housing go?
TurboTom
Post by TurboTom »
Most of the bottom of the head will be welded up and new passages cut.
I will just weld in a T-stat outlet somewhere in the front.
It is an aluminum head......"Cuts Like Butta"
Thanks for the link on the V-12, that is cool
Yes Jeff you could make that happen. I am starting with the 4 to work out all the valve train and fitment issues.
1979 AMC Spirit
FlyinRyan
Post by FlyinRyan »
I'm tuning a turbo 2.5 using the JTEC PCM right now....runs great.
Flyin' Ryan Performance
TurboTom
Post by TurboTom »
What kind of numbers are you seeing?
I will be running the Holley Dominator system on mine.
1979 AMC Spirit
amcinstaller
Vehicle Year: 1980
Vehicle Make: AMC
Vehicle Model: Spirit
Post by amcinstaller »
sorry I haven't been on in a while, what happened to the cheb motor you had in the spirit?
TurboTom
Post by TurboTom »
Got rid of the chevy engine. Going to build the worlds fastest 2.5 Jeep engine :mrgreen:
Just want to do something different with AMC power
1979 AMC Spirit
CobraMarty
TurboTom wrote:Going to build the worlds fastest 2.5 Jeep engine
:rockout: :banana: :cheers:
99 XJ M62 S/C
TurboTom
Post by TurboTom »
Had to get a starting weight
1979 AMC Spirit
mountaineerjeff
Vehicle Year: 1999
any progress. Im starting a revamp on my build, and one major focus is weight. My main idea is to go I6, and possibly a Al head, but then I keep thinking about doing a turbo 2.5. one thing that would really sweeten the pot for doing a 2.5 would be if I could raise the rev limit substantially, and if I could convince you to send one of those heads my one after you do all the heavy leg work :)
N/A 14.9@89
N2O 12.7@104
