I will have a lot of questions as i am on the old continent and everything will have to be shipped over and taxed with something like +25% on the purchase price...
I have a really nicely running 2000 TJ with famous 0331 head casting. No problems so far, with 136.000km on the clock, but some day....
I am about to collect junkyard 1994 engine from WJ in next days - HO version.
I have read that 1994 and 2000 blocks have some differences for brackets and mounts. How much problems can I expect?
Than I was looking at Cleggs kit and it seems nice to me - stage 1.
Alternatively - sourcing parts in different sets and stores. Minly I would focus on RockAuto as it offers most reasonable shipping apart from others (Cleggs, Summit)
THe core component is of course the crank.
Rock offers two options, both reman, 430$ price tag, Advertised as:
ENGINETECH 251700 Includes Connecting Rod Bearings & Crankshaft Main Bearings; Reman Info
w/ centering ring on back of flywheel flange. 2-1/2" neck length. Engines w/ "V" type belts. Includes bearings. Forging # RD67703, 3214723, 3235477. Check for proper physical match before installation. (Only 2 Remaining)
On the other hand - Cleggs balanced kit is 1.150$ (core charge for rods, balancing, molly rings, assembly lube). By your experiance - would you recommend going selected kit?
So gor start - any help on oppinion on block selection (1994 or source a 2000 block (really hard for me over here...) would be great.
Thank you Jeepers
