4.6 crawler build - low end torque....
TJryder
Post by TJryder »
So, I have been following the forum for a while and now started collecting the parts for my build.
I will have a lot of questions as i am on the old continent and everything will have to be shipped over and taxed with something like +25% on the purchase price...
I have a really nicely running 2000 TJ with famous 0331 head casting. No problems so far, with 136.000km on the clock, but some day....
I am about to collect junkyard 1994 engine from WJ in next days - HO version.
I have read that 1994 and 2000 blocks have some differences for brackets and mounts. How much problems can I expect?
Than I was looking at Cleggs kit and it seems nice to me - stage 1.
Alternatively - sourcing parts in different sets and stores. Minly I would focus on RockAuto as it offers most reasonable shipping apart from others (Cleggs, Summit)
THe core component is of course the crank.
Rock offers two options, both reman, 430$ price tag, Advertised as:
ENGINETECH 251700 Includes Connecting Rod Bearings & Crankshaft Main Bearings; Reman Info
w/ centering ring on back of flywheel flange. 2-1/2" neck length. Engines w/ "V" type belts. Includes bearings. Forging # RD67703, 3214723, 3235477. Check for proper physical match before installation. (Only 2 Remaining)
On the other hand - Cleggs balanced kit is 1.150$ (core charge for rods, balancing, molly rings, assembly lube). By your experiance - would you recommend going selected kit?
So gor start - any help on oppinion on block selection (1994 or source a 2000 block (really hard for me over here...) would be great.
Thank you Jeepers ;-)
°O|||||||O°
TJryder
Re: 4.6 crawler build - low end torque....
Post by TJryder »
Just got feedback from a guy that pulled a nicely preserved 1995 engine from a WJ.
In our county gas is expensive, and we only get to get 95+ grade :-) 98 is usual, also 100 available on daily basis :-) So mostly 4.0 were not economical to run and more or less low mileage on them.
Any one with good experience with RockAuto reman cranks?
°O|||||||O°
TJryder
Post by TJryder »
This 12 cw crank good for my build?
https://www.rockauto.com/en/catalog/jee ... shaft,5292
BR M
°O|||||||O°
Hi TJryder,
I'm a warehouse distributor for Scat.
$430.00 will get you a new 3.895 crankshaft with the correct 2.000 snout rather than the more common 2.500 length snout found on the earlier 4.2/258 crankshafts that will require an additional expense of a spacer.
I also carry a full line of custom 4032 forged pistons along with a economically priced forged connecting rod that is fully profiled and bushed allowing for a full floating wrist pin.
If you purchase my connecting rods with my Pistons I'll upgrade the wrist pin to a much lighter and stronger .927 Chevy pin at no additional cost.
Feel free to shoot me a call and I'd be happy to forward you information on this and the rest of my products and services.
Thanks,
Bishop-Buehl Racing Engines
531 N. Lyall Avenue
West Covina, California 91790
Work (626) 967-1000
Cell (626) 673-2203
6sense
Stroker Displacement: 4.0
Vehicle Year: 1999
Vehicle Model: Grand cher
Post by 6sense »
Just wanted to let you know 1995 is a zj a 99-04 is a wj there are some difference in the block from each other.
TJryder
Post by TJryder »
6sense wrote: August 11th, 2018, 4:33 am Just wanted to let you know 1995 is a zj a 99-04 is a wj there are some difference in the block from each other.
Hi!
Yes , I learned that later.... From Graz, Austria...
I am now stripping / cleaning the donor engine.
I am running into a dilemma now...
Basically I wanted to build the engine and do an "over the winter" swap, but would not like to run into major fab work while the engine would be dangling on a hoist....
Small brackets and similar mods are not an issue for me.
BR M
°O|||||||O°
TJryder
Post by TJryder »
Russ Pottenger wrote: August 9th, 2018, 12:02 pm Hi TJryder,
Thanks,
531 N. Lyall Avenue
Work (626) 967-1000
Cell (626) 673-2203
Hi Ross,
Thank you for your offer. FOr sure I will contact you.
I just run in to thinking to just swap the head and cam. For a start.
Maybe the full stroker when I get my hands on a same casting number block.
By the way - Banks headers - are they really torque enhancers?
https://shop.bankspower.com/i-788-51306 ... rokee.html
BR M
°O|||||||O°
TJryder
Post by TJryder »
Russ Pottenger wrote: August 9th, 2018, 12:02 pm $430.00 will get you a new 3.895 crankshaft with the correct 2.000 snout rather than the more common 2.500 length snout found on the earlier 4.2/258 crankshafts that will require an additional expense of a spacer.
Hi Ross,
Just went to RockA and placed a 78 Cj7 crank in my cart:
426$ price
544$ delivered (with tax and import duty of 22%)
Sounds almost like free shipping to me in the end :huh: (20$ shippong cost)
But for sure - new crank with matching bearing beat that all day long...
BR M
°O|||||||O°
TJryder
Post by TJryder »
Slowly but surely:
- 2x 7120 head - will use a better one, one will replace the dodgy 0331 on non stroked engine..
- 56 TBI from ebay
- 12 hole injectors
- some material for regear (31's and will go to 4.10)
- still looking for a busted 4.0 1999+ engine or block locally. Anyone ? Northern Italy, Austria, Hungary, Croatia?
°O|||||||O°
TJryder
Post by TJryder »
Hi,
I have an opportunity to lay hands on 2002 TJ engine with only 40.000 miles on it.
The poor thing was rolled over and totalled.
I am now wondering if I may get out without block machinning phase as thete will be hardly any wear on the cylinders.
What would you guys propose?
°O|||||||O°
I can build you a standard bore piston with a compression distance (CD) of 1.385
That would give you a slight positive deck without having to machine the deck at the block.
If you have a good local machine shop, my recommendation would be to have me build you a piston in the standard bore range, let’s say 3.878 That way you could hone your block a few thousands with a .005 file fit ring package and your back to the proper piston to cylinder wall tolerance with a minimal up cost
My .02
TJryder
Post by TJryder »
Thanks Russ, we will be in touch after I have my second donor engine at home, stripped, cleaned and measured.
Just to share some photos of my progress so far:
Pulled first engine from a wrecked jeep:
Catalyst for disaster was still there:
Engine out, unfortunatley later discovered that will not be fully compatibile with 1999 + TJ:
I went looking for another engine and came across nice 07120 head that I have cleaned and getting it ready for machining / valve train rebuild:
°O|||||||O°
TJryder
Post by TJryder »
Yesterday I spent my day in the shop with donor for 68mm bore TB, to be adapted to TJ bore pattern, basically following Martinbuilt videos:
https://www.youtube.com/watch?v=UsHrXYAcS4o
and
https://www.youtube.com/watch?v=xeASlDAkmdc
I made a shortcut on porting side - just used my lathe and came clear to 68.00mm without a problem:
Donor:
Starting from the bump of 65mm on a lathe. Rear side is concentric and just need to propperly grab it and slowly turn it out to 68mm:
Boring was spot on with cylindrical bottom side, without a step, before touching the shaft or existing flap contact surface!
I also threw in a small taper:
And a slight buttonup with 1.000 grip paper:
°O|||||||O°
SkylinesSuck
Post by SkylinesSuck »
I very much want to see the pics, but they no worky for me :-(
TJryder
Post by TJryder »
SkylinesSuck wrote: November 1st, 2018, 8:04 am I very much want to see the pics, but they no worky for me :-(
Strange, I see them.
do you see this:
BR M
°O|||||||O°
