No power gained from 4.7L srtoke
Basselalawar
Post by Basselalawar »
Hello,
I have a 4.7L 1998
the engine is healthy with no issues, I have hesco throttle body, Gibson headers, 4 hole injector upgrade. the current piston compression ratio is 10:1. I have small gains compared to 4.0L and the engine cant rev to the rev limiter. Didnt do any tune or cps mods.
help is really appreciated
Sean295
Vehicle Model: TJ
Re: No power gained from 4.7L srtoke
Post by Sean295 »
I assume you have a after market cam..if so you will mos likely need to index the distributor.
Was it running fine to start with and something happened or is it a new build?
Try a compression test...make sure your building pressure....make sure your getting plenty of fuel by checking the fuel pressure...those fuel pumps are not the greatest....spark is the next thing...
papaof2
Vehicle Year: 1999
Vehicle Model: TJ
Post by papaof2 »
A tune from frptuning.com / Flyin' Ryan Performance will make all the difference.
SkylinesSuck
Post by SkylinesSuck »
Not if it's not running right first. Ryan won't want to touch it if it isn't. You should see a very noticeable increase in power across the board even with no tune. Do you have a wideband O2 sensor to tell you what your fueling is like? What injectors are you running?
astjp2
I think I'll order a "tab"
Vehicle Year: 1994
Post by astjp2 »
Is the catalytic converter clogged? My stroker runs like a scalded dog...
tablerockfshr
Vehicle Year: 1999
Vehicle Make: xj
Vehicle Model: sport
Post by tablerockfshr »
I had the same thing till I upgraded the fuel pump on a 99 xj with 24lb injectors ...just my situation,,
If the old fuel pump is weak, a new stock replacement would do fine. Rated at 90lph (24gph), that's enough to fuel a 300hp N/A engine.
