Hello,
I have a 4.7L 1998
the engine is healthy with no issues, I have hesco throttle body, Gibson headers, 4 hole injector upgrade. the current piston compression ratio is 10:1. I have small gains compared to 4.0L and the engine cant rev to the rev limiter. Didnt do any tune or cps mods.
help is really appreciated
No power gained from 4.7L srtoke
Basselalawar
Sean295
Re: No power gained from 4.7L srtoke
I assume you have a after market cam..if so you will mos likely need to index the distributor.
Was it running fine to start with and something happened or is it a new build?
Try a compression test...make sure your building pressure....make sure your getting plenty of fuel by checking the fuel pressure...those fuel pumps are not the greatest....spark is the next thing...
papaof2
A tune from frptuning.com / Flyin' Ryan Performance will make all the difference.
- SkylinesSuck
Not if it's not running right first. Ryan won't want to touch it if it isn't. You should see a very noticeable increase in power across the board even with no tune. Do you have a wideband O2 sensor to tell you what your fueling is like? What injectors are you running?
astjp2
- Vehicle Year: 1994
Is the catalytic converter clogged? My stroker runs like a scalded dog...
tablerockfshr
- Vehicle Make: xj
- Vehicle Model: sport
I had the same thing till I upgraded the fuel pump on a 99 xj with 24lb injectors ...just my situation,,
If the old fuel pump is weak, a new stock replacement would do fine. Rated at 90lph (24gph), that's enough to fuel a 300hp N/A engine.
