XJ block into a TJ
Hunter1212
XJ block into a TJ
Post by Hunter1212 »
New guy here.
I have a 4.6 stroker from a 1998 XJ. Already built. I have a 2000 TJ with blown engine. I know the accessories don't match up. I was thinking of using all XJ brackets for the P/S, A/c and alternator. Has anyone done this?
TP
Re: XJ block into a TJ
I haven't done it but if you have all the XJ accessory mounting brackets, engine mount brackets, and water pump, you should be able to make it work.
Stroker Build Stroker Recipes
Hunter1212
Thanks,
I’ll give it a try
Brianj5600
I think I'll order a "tab"
Vehicle Year: 2004
Post by Brianj5600 »
I thought only 99+ WJ or 2000+ TJ will bolt in without custom motor mounts.
Strong Poster
Strong Poster
Post by Russ Pottenger »
Stinkyfab Racing will make you the motor mounts
