New guy here.
I have a 4.6 stroker from a 1998 XJ. Already built. I have a 2000 TJ with blown engine. I know the accessories don't match up. I was thinking of using all XJ brackets for the P/S, A/c and alternator. Has anyone done this?
TP
XJ block into a TJ
Re: XJ block into a TJ
I haven't done it but if you have all the XJ accessory mounting brackets, engine mount brackets, and water pump, you should be able to make it work.
Hunter1212
Thanks,
I’ll give it a try
I’ll give it a try
Brianj5600
- I think I'll order a "tab"
- Vehicle Year: 2004
I thought only 99+ WJ or 2000+ TJ will bolt in without custom motor mounts.
- Strong Poster
Stinkyfab Racing will make you the motor mounts
