Help with getting all the right parts for my stroker kit
RockspotterYT
Post by RockspotterYT »
Alright, so I have decided to go with the stage 2 4.6 Jeep stroker kit from Clegg Engine.
https://www.cleggengine.com/jeep-4-0...-8-8-1c-r.html
Now I just need to figure out all the other little bits I need to make sure I have for this project. I have a total budget of up to 8-9K, but would like to stay around 5k, but am willing to spend extra to do it right the first time. I am at this point asking about what options I should get with my kit from Clegg Engine. I also assume I will need their camshaft upgrade kit to pair with my stroker, or are there other options for that?
https://www.cleggengine.com/jeep-4-0...1987-2005.html
So far, my list is the Clegg kits, oil pump, fuel injectors, headers, intake manifold, water pump, and throttle body that need upgrading. I'm sure there are loads and loads of parts I'm missing, which is why I am asking for help. I need any part upgrade recommendations to do with this build, even if it is something I have not listed because I haven't thought of it yet, and I am asking for some insights into what parts I should add to the kit and which ones I can/should buy elsewhere(exact part numbers/website links are HIGHLY ENCOURAGED). My goal is to make the best stroker kit I can make, so please, anything helps in this process. I plan to start the teardown process soon, once I start getting a mostly complete parts list together, to avoid filling my storage shed with parts that aren't going back onto the Jeep. The only product I have purchased as of right now is an aftermarket airbox that will allow me to have my snorkel as well as a cone filter for airflow, as I am planning on a larger throttle body(I've heard 62mm is ideal?). Also, feel free to direct me to any other threads that answer my questions as well!
eugenebuilt
Vehicle Model: TJ
Re: Help with getting all the right parts for my stroker kit
Post by eugenebuilt »
For the best stroker you can make consider a hydraulic roller cam and roller lifter set from Newcomer, link here: https://www.newcomerracing.com/store/p4 ... AMC.html#/
You’ll want to source injectors with greater capacity than stock, somewheres in the 26lb/hr range @ 49.2psi
Keep us updated :cheers:
RockspotterYT
Would I also need a higher-flow-rate fuel pump over stock to pair with the injectors as well? Also, I assume with the cam I would effectively be replacing the stage 2 cam kit I would've gotten from Cleggs if I go that route.
eugenebuilt
Vehicle Model: TJ
The stage 2 kit is likely fine, depending on your build
I was partially joking about the Newcomer cam kit, it’s very costly, but it would be incredibly cool to see it applied by someone here in this forum
Stock pump should be fine as long as it tests strong
RockspotterYT
eugenebuilt wrote: July 9th, 2026, 1:04 pm The stage 2 kit is likely fine, depending on your build
I figured I'd buy the stage 2 cam kit to go with my stage 2 internals kit so basically doing stage 2 for both from Cleggs, but after messaging with cleggs, it turns out that stage 2 doesn't necessarily mean its what I want, it sounds like from what they said stage 1.5 would be the ideal for their stage 2 kit because of how the stage 2 and 3 are top end power and stage 1/1.5 are low to mid, Newcomer cam kit does look cool but it is definitely costly, if I was going all out with their 5.0 kit I would probably be considering it, but with my budget I'm sticking to a 4.6 which will be more than enough power anyway.
eugenebuilt
Vehicle Model: TJ
Probably good advice from Clegg, make sure your build matches your intent. Same sentiment here with the 1-1.5-ish stage build. Better IMO for my intended use mostly street driving with some moderate trail use. I’m in an emissions area.
RockspotterYT
eugenebuilt wrote: July 9th, 2026, 2:38 pm I’m in an emissions area.
I assume emissions with a stroker are the same as before, just have a cat on it and no codes, and you're good to go? I'd be curious if I could get away catless, but I kinda doubt it.
Gorilla
Learning to use the board
Stroker Displacement: 4.0
Vehicle Year: 2004
Vehicle Model: TJ
Post by Gorilla »
Increasing compression can increase NOx emissions, but as long as you don't disable the closed loop capability of your jeep and the intake and exhaust are sealed properly it'll all be fine. At least with the lackeys running the rolling sniffer tests here. My 4.0L never exceed 1/10th the allowable in any metric. There's a fair amount of headroom locally, but a bad cat, leaking exhaust or vacuum leak could easily trip you up.
