Help with getting all the right parts for my stroker kit
RockspotterYT
Post by RockspotterYT »
Alright, so I have decided to go with the stage 2 4.6 Jeep stroker kit from Clegg Engine.
https://www.cleggengine.com/jeep-4-0...-8-8-1c-r.html
Now I just need to figure out all the other little bits I need to make sure I have for this project. I have a total budget of up to 8-9K, but would like to stay around 5k, but am willing to spend extra to do it right the first time. I am at this point asking about what options I should get with my kit from Clegg Engine. I also assume I will need their camshaft upgrade kit to pair with my stroker, or are there other options for that?
https://www.cleggengine.com/jeep-4-0...1987-2005.html
So far, my list is the Clegg kits, oil pump, fuel injectors, headers, intake manifold, water pump, and throttle body that need upgrading. I'm sure there are loads and loads of parts I'm missing, which is why I am asking for help. I need any part upgrade recommendations to do with this build, even if it is something I have not listed because I haven't thought of it yet, and I am asking for some insights into what parts I should add to the kit and which ones I can/should buy elsewhere(exact part numbers/website links are HIGHLY ENCOURAGED). My goal is to make the best stroker kit I can make, so please, anything helps in this process. I plan to start the teardown process soon, once I start getting a mostly complete parts list together, to avoid filling my storage shed with parts that aren't going back onto the Jeep. The only product I have purchased as of right now is an aftermarket airbox that will allow me to have my snorkel as well as a cone filter for airflow, as I am planning on a larger throttle body(I've heard 62mm is ideal?). Also, feel free to direct me to any other threads that answer my questions as well!
eugenebuilt
Re: Help with getting all the right parts for my stroker kit
Post by eugenebuilt »
For the best stroker you can make consider a hydraulic roller cam and roller lifter set from Newcomer, link here: https://www.newcomerracing.com/store/p4 ... AMC.html#/
You’ll want to source injectors with greater capacity than stock, somewheres in the 26lb/hr range @ 49.2psi
Keep us updated :cheers:
