So what is your setup?
76CJ5
Post by 76CJ5 »
With all the talk of the quench high, CR, and how much ping you can live with. What are some of the people's motor combination that you have done and tell us what you would change or not change. For people like me that have most of the parts together but are still reading and trying to decide what the best combination is. :banghead: I can read till blue in the face but real world statments are worth a lot.
1976 CJ5 with no motor. Can't decide how to build a stroker. Thats why I am here.
oletshot
Re: So what is your setup?
Post by oletshot »
x2!
'98 XJ 2-door, '94 YJ.
Stroker Displacement: 4.9
Post by jsawduste »
In my sig.
Bottom line. Custom Diamond pistons with zero deck on a stock deck height block. Pistons machined to allow for a 9.48 compression ratio with .043 quench. After figuring total cylinder volume at TDC
What ping ??
93 4.0 block
12 weight 4.2 crank
.080 Diamond pistons
Eagle rods
balanced
274/480 Cam
Mopar rollers with Engel springs
.043 Quench @ 9.48 Compression
Ported head
01 intake with 64 mm TB
Edlebrock header
Misc other stuff
Don`t need a Hemi.
Flash
Post by Flash »
jsawduste wrote:In my sig.
What ping ??
A couple question..............What octane are you using(87-91?)..............and what is the altitude where you live.......
Flash.
Shark
Consistent
Consistent
Post by Shark »
Flash wrote: A couple question..............What octane are you using(87-91?)..............and what is the altitude where you live.......
Flash.
exactly what i was going to ask.
'95 XJ 4door 4.0 aw4 2" 31's
seanyb505
Stroker Displacement: 280ci
Post by seanyb505 »
I really cant see myself spending 600 dollars on pistons alone, even with the 120 offset of not having to buy 258 rods.
97 XJ 4.6
90 MJ 4.0 - sold
eliv1
I think I'll order a "tab"
Post by eliv1 »
an 88 israeli CJ8.
4.5L stroker, on a 258 overbored block (way overbored to accept 4.0 std slugs), 4.2L Crank (12 ct-wt)
1:9.7 CR, stock Felpro Head gasket, quench ~ 0.081", CompCams 68-231-4 Camshaft, Ported HO 7120 4.0L head with
Mopar Performance valve springs #5249464, 4.0L MPFI Fuel Injection with 24lb/hr FMS Injectors.
Running on 95RON (diffrent from US 95 octane, that's what we have here in israel) with absolutly NO PING AT ALL,
didnt have a ping even with carb. :roll:
oh, and I live at Sea Level.
88 CJ8, 4.5L Stroker ,P&P Head ,Compcam 68-231-4 cam , 4.0L Junkyard MPI , 99 Intake, Borla Header,2.5" Flowmaster + piping,Electric Fans;SUA 4" lift on 33" tires ;4.11's Dana 44 F&R LockRight , High Steer with CTM's ;OBA;Full Cage.
Post by jsawduste »
seanyb505 wrote:I really cant see myself spending 600 dollars on pistons alone, even with the 120 offset of not having to buy 258 rods.
First off I am at approx 600 feet above sea level. Been running 93 octane but feel that the engine would be fine on a lower octane fuel.
Secondly the pistons from Diamond where no where near 600. Much less, say around 200 less.
93 4.0 block
12 weight 4.2 crank
Eagle rods
balanced
274/480 Cam
Ported head
Edlebrock header
Misc other stuff
Don`t need a Hemi.
Shark
Consistent
Consistent
Post by Shark »
eliv1 wrote:an 88 israeli CJ8.
i wouldnt really call this a "stroker". youve got the standard stroke for your 258 block. cool steup though. how much overbore is that?
seanyb505
Post by seanyb505 »
jsawduste wrote: Secondly the pistons from Diamond where no where near 600. Much less, say around 200 less.
Still 400 is a lot of money to me.
97 XJ 4.6
90 MJ 4.0 - sold
eliv1
Post by eliv1 »
tigerShark wrote: i wouldnt really call this a "stroker". youve got the standard stroke for your 258 block. cool steup though. how much overbore is that?
it is exacly a stroker, just 258 block. since it is a 258 crank, and 4.0L standard pistons (0.125" overbore) giving the displacment of 4.5L.
76CJ5
Post by 76CJ5 »
eliv1 wrote:
tigerShark wrote: wouldn't really call this a "stroker". you've got the standard stroke for your 258 block. cool setup though. how much overbore is that?
it is exactly a stroker, just 258 block. since it is a 258 crank, and 4.0L standard pistons (0.125" overbore) giving the displacement of 4.5L.
But you have not changed the stroke of the motor any. Just an overbore
oletshot
Post by oletshot »
I agree, not a stroker by definition, but throw in the 4.145" stroker crank for the 258 and that becomes a really unique 4.8L stroker. I think we had a discussion on the yahoo group about whether it was possible to bore the 258 that much, guess that answers that question. 8-)
Flash
Post by Flash »
How about running a tank of mid grade, For..............Science :mrgreen:
Flash.
jeepinwi
Learning to use the board
Post by jeepinwi »
I have about 9.25 CR and .095" quench. I ive at 800 feet elevation, and I run 89 octane all the time. Also, all the fuel around here has 10% ethanol.
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Semrush [Bot] and 2 guests
