So what is your setup?
- 76CJ5
With all the talk of the quench high, CR, and how much ping you can live with. What are some of the people's motor combination that you have done and tell us what you would change or not change. For people like me that have most of the parts together but are still reading and trying to decide what the best combination is.
I can read till blue in the face but real world statments are worth a lot.
1976 CJ5 with no motor. Can't decide how to build a stroker. Thats why I am here.
- oletshot
Re: So what is your setup?
x2!
'98 XJ 2-door, '94 YJ.
- Stroker Displacement: 4.9
In my sig.
Bottom line. Custom Diamond pistons with zero deck on a stock deck height block. Pistons machined to allow for a 9.48 compression ratio with .043 quench. After figuring total cylinder volume at TDC
What ping ??
What ping ??
93 4.0 block
12 weight 4.2 crank
.080 Diamond pistons
Eagle rods
balanced
274/480 Cam
Mopar rollers with Engel springs
.043 Quench @ 9.48 Compression
Ported head
01 intake with 64 mm TB
Edlebrock header
Misc other stuff
Don`t need a Hemi.
12 weight 4.2 crank
Eagle rods
balanced
274/480 Cam
Ported head
Edlebrock header
Misc other stuff
Don`t need a Hemi.
- Flash
A couple question..............What octane are you using(87-91?)..............and what is the altitude where you live.......jsawduste wrote:In my sig.
What ping ??
Flash.
- Shark
exactly what i was going to ask.Flash wrote: A couple question..............What octane are you using(87-91?)..............and what is the altitude where you live.......
Flash.
'95 XJ 4door 4.0 aw4 2" 31's
- seanyb505
- Stroker Displacement: 280ci
I really cant see myself spending 600 dollars on pistons alone, even with the 120 offset of not having to buy 258 rods.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
eliv1
- I think I'll order a "tab"
an 88 israeli CJ8.
4.5L stroker, on a 258 overbored block (way overbored to accept 4.0 std slugs), 4.2L Crank (12 ct-wt)
1:9.7 CR, stock Felpro Head gasket, quench ~ 0.081", CompCams 68-231-4 Camshaft, Ported HO 7120 4.0L head with
Mopar Performance valve springs #5249464, 4.0L MPFI Fuel Injection with 24lb/hr FMS Injectors.
Running on 95RON (diffrent from US 95 octane, that's what we have here in israel) with absolutly NO PING AT ALL,
didnt have a ping even with carb.
oh, and I live at Sea Level.
seanyb505 wrote:I really cant see myself spending 600 dollars on pistons alone, even with the 120 offset of not having to buy 258 rods.
First off I am at approx 600 feet above sea level. Been running 93 octane but feel that the engine would be fine on a lower octane fuel.
Secondly the pistons from Diamond where no where near 600. Much less, say around 200 less.
93 4.0 block
12 weight 4.2 crank
Eagle rods
balanced
274/480 Cam
Ported head
Edlebrock header
Misc other stuff
Don`t need a Hemi.
12 weight 4.2 crank
Eagle rods
balanced
274/480 Cam
Ported head
Edlebrock header
Misc other stuff
Don`t need a Hemi.
- Shark
i wouldnt really call this a "stroker". youve got the standard stroke for your 258 block. cool steup though. how much overbore is that?eliv1 wrote:an 88 israeli CJ8.
- seanyb505
Still 400 is a lot of money to me.jsawduste wrote: Secondly the pistons from Diamond where no where near 600. Much less, say around 200 less.
97 XJ 4.6
90 MJ 4.0 - sold
97 XJ 4.6
90 MJ 4.0 - sold
eliv1
it is exacly a stroker, just 258 block. since it is a 258 crank, and 4.0L standard pistons (0.125" overbore) giving the displacment of 4.5L.tigerShark wrote: i wouldnt really call this a "stroker". youve got the standard stroke for your 258 block. cool steup though. how much overbore is that?
- 76CJ5
eliv1 wrote:it is exactly a stroker, just 258 block. since it is a 258 crank, and 4.0L standard pistons (0.125" overbore) giving the displacement of 4.5L.tigerShark wrote: wouldn't really call this a "stroker". you've got the standard stroke for your 258 block. cool setup though. how much overbore is that?
But you have not changed the stroke of the motor any. Just an overbore
- oletshot
I agree, not a stroker by definition, but throw in the 4.145" stroker crank for the 258 and that becomes a really unique 4.8L stroker. I think we had a discussion on the yahoo group about whether it was possible to bore the 258 that much, guess that answers that question.4.5L stroker, on a 258 overbored block (way overbored to accept 4.0 std slugs), 4.2L Crank (12 ct-wt)
- Flash
How about running a tank of mid grade, For..............Sciencejsawduste wrote:seanyb505 wrote:I really cant see myself spending 600 dollars on pistons alone, even with the 120 offset of not having to buy 258 rods.
Flash.
jeepinwi
- Learning to use the board
I have about 9.25 CR and .095" quench. I ive at 800 feet elevation, and I run 89 octane all the time. Also, all the fuel around here has 10% ethanol.
99 Cherokee SE - 2 door, 4x4, 4.6L stroker, 5 speed, 8.25 rear, 60mm TB, stock exhaust
